knock?
c1500
knock?
Post by c1500 »
so i have a 95 civic si with a d16 z6 motor. i have intkae header and exhaust. i just got a s300 for it that was already in another ecu. when i changed the computers everything started up fine but the check engine light is on. on the hondata program it says theres a knock or knock sensor is no good? but with my stock ecu it didnt throw any cels. is there anything that could be causing this i didnt mess with anything on the program other than the 2step any help would be greatly apprieciated
thanx!
95 civic si, d16z6 I.H.E s300
Does the ECU you are using have knock control?
http://www.hondata.com/ecus.html
c1500
Post by c1500 »
its the p28 ecu and that chart says no? so is that my problem there?
how would a make the engine light go away?
thanx for the quick reply!
In Misc Parameters, disable the knock sensor.
c1500
Post by c1500 »
okay thanx alot!!
