TUNGSTEN W and Palmlog issue
QUICKSILVER RACING
Post by QUICKSILVER RACING »
I have a PALM TUNGSTEN W and a markspace cable.
I coundn't connect to the interface box.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
Palm cable
Which cable do you have? I don't think markspace makes the correct cable for the Tugsten. The cable should be a modem cable, 9 pin, powered from the Palm, and must have electronics inside the cable to convert the voltage levels.
QUICKSILVER RACING
I was thinking that. but availability of cables here are NIL. Best thing is to purchase the cable from you.
+639178954747
QUICKSILVER RACING
electronics as in RS 232?
+639178954747
QUICKSILVER RACING
I checked my cable again and I also checked Mark space.
They have a DCU-m9 modem cable which is the one that I ordered. I think they sent me the wrong cable DCU-H9 which is the Hotsync serial cable.
I will order it through you guys.
+639178954747
QUICKSILVER RACING
I have bought the correct cable from Pcables.com.
I still couldn't connect to the Interface box.
I don't know why.
+639178954747
hondahatch
M505/Tungsten
Post by hondahatch »
QuickSilver
Does the Palm 505 has RS-232 level pin out ? Or is it TTL like the Visor ?
I notice that the Tungsten uses the same connector as the Tungsten and wondering whether you get Palmlog to work on your Tungsten ?
What cable did you use ?
Does it have any TTL to RS232 level conversion on the cable you use ?
Many thanks
