noob question
newsoltsc
noob question
Post by newsoltsc »
Ok, I have stock 240cc injectors and I want to replace them with some 550cc injectors I have.
In s300 all I have to do is change the current injector size in Parameters> Fuel Trim right?
Will it run fine like a basemap, or will it spit too much fuel into the motor?
Reason why I want to replace them is because when I installed the turbo I setup an FMU (this was done before I bought the s300), and it's currently running with the 240cc injectors and the FMU with the s300.
All I did was copy the last fuel column and put them in the boost column and it runs fine.
I do realize I'll have to change the fuel tables in boost, that is fine.
Thanks,
-Jose
-Jose
It will need to be properly tuned with the new larger injectors. Different sized injecotrs have different flow characteristics and also different voltage vs. dead time compansations.
newsoltsc
Post by newsoltsc »
Gotcha. Just wondering.
I wanna get rid of this FMU lol.
Guess I gotta tune this crappy motor lol
-Jose
