1996 B16A2, way to tune but retain OBD2?
boostedranger
Post by boostedranger »
I am looking into putting forced induction on a 1996 Del Sol with a B16A2. I live in NJ so I need to retain OBD2 capabilities in order to pass state inpsection. What are my tuning options? If I read the website correctly Hondata requires that I purchase an OBD1 ECU and swap it in, correct?
Thanks in advance for any help
Jon
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
You cannot retain OBD2 and use a Hondata system.
boostedranger
Thank you, thats what I gathered from reading your site, but wanted to clarify and see if anyone could point me in the right direction.
Jon
