Which OBD is the ECU P3X ??
borsti
Post by borsti »
Hi I have a Big Problem ....
I have the car civic ej9 with engine d14a3 with ecu p3x
i will up to d16z6 but the problem is wire harness ...
the p3x has 2 plugs not more :?
You will probably have to change quite a bit of the wiring harness in the car to use a compatible OBD1 ECU with a Hondata system.
