Nitrous control question
PR8urvtec
Post by PR8urvtec »
I am installing my dry shot nitrous kit back on to my LS engine. When I first installed the kit I did not have a S300 unit so I was running the vacuum lines to the fuel pressure and ran a fuel pressure saftey switch... etc.
My question is. Do I need to run all the vacuum lines and fuel pressure "tee" even though I am going to control everything with the Aux/nitrous feature from S manager? I can control my fuel trim and ignition timing through hondata and all the tee (bypass valve) will do it trip my ECU into adding more fuel anyway. I did a wire tuck on the bay so it would be nice to loose all teh vacuum lines and decrease chances of leaks and such. Would this be a question for Holley NOS?
Thanks,
Ryan
IF you are using the s300 and ECU to control all the nitrous parameters then there should be no ned for extra vacuum lines or controllers.
PR8urvtec
Post by PR8urvtec »
Sweet just what I was thinking.
Thanks for the help.
