Wideband oxygen sensor
Bard
Post by Bard »
Hello. I own an O2 sensor without OEM packet,
sensor has writnings. "DU2 Denso 192400-1091 04L22"
is it a 36531-PRB-A01 wich is needed for dual harness setup on a TSX ?
It has four wires green, white, black, black.
Are there any other costs?
Yes.
- Air Fuel ratio sensor from a US 2004-2005 D17 Civic (Part # 36531-PLR-003)
- VTC cam control mechanism to allow greater than 25 degrees cam advance
The Air fuel sensor is equivalent to the RSX-S sensor. This is a plug in replacement for the front air fuel ratio sensor. You may purchase this from your Honda or Hondata dealer . An Air fuel ratio sensor is required to pass a smog test (note that the K-Pro is for off road use only) and can also be datalogged for tuning purposes.
You will need to machine a TSX VTC mechanism to allow 45 degrees of cam advance.
Bard
Post by Bard »
It is well known that O2 sensor from RSX S fits dual harness setup it`s part number is 36531-PRB-A01.
So i just whant to know if my sensor is an RSX-S one.
The RSX sensor is the wrong one and will not plug in.
Bard
Post by Bard »
RSX one wires are just shorter it is not a problem at all.
