Kpro and VTC wiring between 02-04 and 05-06 rsx harness
Posted: Sat Nov 28, 2009 8:56 pm
The 05-06 VTC uses the VTC(+) and power ground, which is different from the 02-04 which has VTC+ and - wiring in the ECU plug.
What would the wiring involve to use an 05-06 VTC setup on an 02-04 KPRO ecu? Grounding the VTC- pin on the ECU to Power ground?
Would it be easier just to swap in an older style VTC solenoid?
