Injector Options for S300
Manny1987
Post by Manny1987 »
In Crome Pro theres options to select certain injector information. For example High or Low impedance injectors and the voltage compensations, & by manufacturer.That way everything is dialed in for you as far as MS's and dead times etc. Is there any ideas of ever making or adding an options like this for at least a majority of the leading injector manufacturers. I know theres compensations but maybe this would help many people tune there cars.
Manny1987
Post by Manny1987 »
Any thoughts on this Spunkster?
Many of the injector manufacturers do not supply this information, and the dead times from independent testing is copyright, so we can't include those values. However, the main reason is that we've found the dead times commonly listed are not correct for Honda ECUs - generally they are too low by 0.2 ms.
