RC 440cc Injectors
_Mozz_
RC 440cc Injectors
Post by _Mozz_ »
Hi,
Might need to change my injectores soon. Was thinking of RC 440cc.
What needs to be changed on the FlashPro calibration?
Regards
You need to change the injector size in the calibration window under Fuel, and then tune it properly to get the correct AF ratio.
_Mozz_
Post by _Mozz_ »
Is that it??
I was under the impression something else had to be done!?
Regards
_Mozz_
Post by _Mozz_ »
What about the Injector opening times??
If you have the injector dead time information that would also be the time to put that in.
_Mozz_
Post by _Mozz_ »
Hi,
I was looking on your Calibrations.
Noticed that the Civic SI (witch has same injectors as me), Stock equivalent Calibration has the same Injector Opening time as the FN2 Stock equivalent Cal.
So, i see that there is a Civic SI Starting Calibration for 440cc injectors, so, could i use those Injector Opening Times on mine??
Paulo
_Mozz_
Post by _Mozz_ »
Hondata?? Any thoughts??
nunoctr
Post by nunoctr »
there is a MAP 440 cc injectors starting calibration for the fn2 on flash pro.
_Mozz_
Post by _Mozz_ »
Its for the Civic Si (FG2/FA5).
And thats what i am asking, could that be used on our FN2??
Also, i would like a MAP cal.
Regards
nunoctr
Post by nunoctr »
it's for both cars.
_Mozz_
Post by _Mozz_ »
:D
All i need now is a IPS K2 Calibration to start playing...!!
Regards
Paulo
dinoc
Post by dinoc »
Are there any MAF calibration for this 440/410 injectors ?
Euro Honda Accord CL9
mw1978
Post by mw1978 »
dinoc wrote:Are there any AFM calibration for this 440/410 injectors ?
NOOOOOOOO!!!! Only for MAP
