s300 started smoking on first drive
supafil25
Post by supafil25 »
- the calibration - stock d16z6 s300 cal
- 94 civic ex
- p28
- stock unmodified wiring
- so i installed the p28 w/ s300 into my civic, hooked up the laptop and uploaded the cal. setup my basic settings. A/F was good. as soon as i started driving down my street i smelled something elctrical burning so i immediately shut the car off and unplugged the ecu. opened it up and Q31 was burnt amd broken apart.
lowblow
Post by lowblow »
Seems like you have very bad soldered job there
How install s300 for your p28 ?
supafil25
Post by supafil25 »
i did not solder in Q31 so i dont understand why it burned like that...
fly_n
Post by fly_n »
Maybe u should change thread title to "P28 started smoking on 1st drive".
Q31 drives the purge solenoid.
Lot of people blow it up by accidently switching the plugs to the IAT & purge solenoid,check that first.
Check the purge solenoid circuit out well while your at it for any other wiring errors or faults.
Maybe your trying to use the purge output to run something else & have wired it incorrectly.
Otherwise did u inspect the ECU when u got it,maybe someone else blew it up for u & offloaded it to u?
supafil25
Post by supafil25 »
im used to my kpro lol
whats a purge valve?
fly_n
Post by fly_n »
Its emission controls.
Its the solenoid controlled valve that purges the fuel vapours from the charcoal canister into your throttle body.
Look for the vac hose that runs between the canister & throttle body,somewhere along that hose u will find the purge valve with 2 pin wiring plug connected to it.
If the valve is not present,then just verify the wiring is not still incorrectly attached to anything else or damaged/shorted/etc.
Verify this wiring is actually the purge wiring,it usually has like a red wire & a yellow/black wire attached. Yellow/black is power(12V) & red wire runs to A20 at ECU
IAT plug usually has a red/yellow & a green/blue wire attached.
locash
Post by locash »
You have the purge and the IAT plug switched. This has nothing to do with the Hondata product..
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
supafil25
Post by supafil25 »
so how do i fix this? can i just get rid of it?
supafil25
Post by supafil25 »
but is this ecu still good?
THe ECU should still function, but will no longer operate the purge valve.
supafil25
Post by supafil25 »
is that a big issue that it wont purge?
kinetics
Post by kinetics »
Your wiring's got to be wrong.
ECU is fine.
Purge valve isn't that big a deal.
This is an easy fix. Pick up a spare transistor at Radio Shack or wherever, and get to soldering.
lowblow
Post by lowblow »
Check your sensor plug if is melt or damage before replug to sensor after ECU fix
