Autotune not Working?????????????
thudreem
Post by thudreem »
Ok, I have read the AutoTune section a million times and I cannot seem to get it to work ok. I have a decent basemap on the car but I still is running rich, So I wanted to turn to the Autotune to correct this matter.
So this is what I do, please tell me if I am doing something wrong here::
I open my base map that runs pretty good
I set the base map
Then I HOLD DOWN ALT A to auto tune the whole time i am going through the cells, basically using the braking technique, but I do not see any of the fuel cells changing at all. I can open the view of the lambda and see the % changes but I was told not to look at that, just watch the normal view of the low speed map
I have the whole work, s200 with datalog, rom editor, hondalogger, romulator, wideband, and of course a laptop. can somebody please ttell me what it is that I am doing wrong, or if U can tell me what is it that U do and it works.
If somebody could call me or just reply or email me with a # whatever here is my cell # 570-441-1734 and my email is sean18337@yahoo.com thanks a lot
thanks a lot
I know this is not supported, but I got the Autotune feature to work on my 87 Integra with vac advance (not even using timing tables) with a P28, using the exact instructions on the website. Make sure that your romulator is actually doing somethign by adjusting the idle speed and see if it changes. If it doesn't then the romulator is not communicating.
thudreem
AUTOTUNE!!!!
Post by thudreem »
Yeah my romulator works great, I can change anything I want on the FLY, but when I hold down ALT A nothing changes in the tables.
So basically you can set as base map, then hold down alt A and hondata will change the actual #'s in the low speed map with the normal view on??
