P28 no power
Poey2
P28 no power
Post by Poey2 »
Hi,
My s300 p28 ecu just died last night for no reason. It started with occasional power then no power. When I said no power there is no light and no connection to the labtop. Then it would power up after several seconds. Now its not working at all.
Is it the s300 or a bad ecu?
thanks
More than likely it is the ECU. Have you chekced inside the case? Does it smell funny?
Poey2
Post by Poey2 »
the ecu smells fishy... ??
I have a P75 ecu that i would like to use. Can i transfer the S300 to the P75 and still have Hondata control vtec?
The fishy smell is the main capacitor that has died. You may be able to replace it, but usually it damages the circuit board. IF you use the P75 you will have to use a relay and use the alternate VTEC output.
Poey2
Post by Poey2 »
thanks for answering my questions
I have found this vtec conversion online that i would like to experiment with.
http://www.xenocron.com/vtec-conversion ... ecfd29f4e9
If i use this kit will i still need to use a relay and an alternate vtec output on my P75?
thanks again.
no
