Launch control
ROM Editor 4 tuning software questions and answers.
V-Spec race development
Launch control
Post by V-Spec race development »
By selecting the "always on" and datalog it from the S200 to update, will the launch control work w/o a switch? is it the same as the S300 when you select "always on" Thank you.
Never mind on this one I figured this one out already.
My other question is, how come when I set the launch limiter to 3500rpm and try to rev the motor and the tach showing 4500rpm? why is this. It's 1000rpm off.
My tach is accurate because I tried it on me s300 and set the launch limiter to 3500rpm and it is accurate and shows 3500rpm dead on.
If you datalog, what does it show there?
Revspeed
Post by Revspeed »
V-Spec race development wrote:Never mind on this one I figured this one out already.
i had this problem too after i update the software to 1.1 but mine was like 2500 off
also u should check your a/f after u burn the chip its different from when u tune on ur romulator...........
-somethings up before i updated it was all fine.......................
