k24 I/RH/E
k24ep3
k24 I/RH/E
Post by k24ep3 »
there is a calabration i noticed for the tsx, i have an 05 with Intake race Headers Exhaust and there is a calibration for this setup, but it says in the note section of the calibration that it uses a 45 degree VTC and I have not touched my vtc gear yet... will this be ok to use if i still have my stock VTC gear? because im pretty sure the tsx comes with a 30 degree if i remember correctly...
Yes, you just won't get the benefits of the full range of motion of the cam gear.
k24ep3
Post by k24ep3 »
Spunkster wrote:Yes, you just won't get the benefits of the full range of motion of the cam gear.
wouldnt the calibration damage my vtc gear if I don't adjust it before uploading? Should I bring all my advance angles down to 30 then retune?
it will not damage anything as it physically cannot advance past 30 degrees.
