noob to kpro , started the car and idle Fluctuating 1k,2k ?
chillii
Post by chillii »
what should i do? please help!
yellowle
Re: noob to kpro , started the car and idle Fluctuating 1k,
Post by yellowle »
chillii wrote:what should i do? please help!
i have the same - how did you fix it?
YLE
You probably need to clean your Idle control valve.
yellowle
Post by yellowle »
Spunkster wrote:You probably need to clean your Idle control valve.
Thanks - done that today
I think that may of fixed the hunting
The engine idles perfectly when cold - then rises slowly - im new to this but the software is great.
I did notice in the KDL that the TPS is reading 1% - that's possibly the answer - will take a decent datalog tomorrow.
YLE
yellowle
Post by yellowle »
Update
This really troubled me but I can report the following:-
a) the cleaning of the IVAC stopped the hunting
b) the idle speed settled after 7 minutes (yes it took that long and can take longer) - but it all settled down once the "learning process" was complete.
Works perfectly.
This is a JDM K20A with a PRC ECU.
YLE
