AFR will not read below 11.89
wantasol
Post by wantasol »
I am running a PLX M300 which registers AFRs below 11.89 fine. However in hondata, it will not log or show below 11.89. I am running the wideband input to the ELD wire. Hondata is set to register the wideband on this wire. Under the options, sensors, ELD is set to 0 to 5 V range, AFR is set 10-16 range. The voltage offset in the closed loop tab is -0.33 V. ELD is disabled in the check box.
Any ideas?
Have you cut the resistors like the instructions say?
wantasol
Post by wantasol »
No resistors were cut.
http://www.hondata.com/techplxwiring.html
It said some ecus may need them removed so I was not sure if that was necessary. I can remove them if that is your recommendation.
