Cold Start
leafs31
Cold Start
Post by leafs31 »
Return the cranking fuel trim to 0%
- For Race calibrations only, alter the water temperature compensation cranking to:
This should work for both stock and aftermarket injectors.
Does Kpro have something like this I need something where my water temp is this much so we add this much more cranking fuel and if the temp is warmer we take away more cranking fuel trim.
When its cold and I change the cranking trim to add more fuel it starts fine but days when it warms up quite a bit then the engine is just flooded and I have to remove more fuel then.
No it does not have this option. There are fuel compensation tables and cranking fuel adjustment tables though. This ecu works differently than a FlashPro.
leafs31
Post by leafs31 »
I don't see these tables anywhere. Would they be under fuel trim all I see is Injector Voltage and Cranking Base Injector Pulse tables. I know where the fuel compensation tables are but need something for cranking, all I see is idle and light load stuff.
The fuel trim tab has Cranking Base Injector Pulse.
http://www.hondata.com/help/kmanager/fu ... =fuel+trim
sass
Post by sass »
Hondata, you can make a separate tab for the cold start the engine as a fuel and for ignition in the K manager / parameters / cold start engine????
Below 300 rpm runs cold start compensation above 300 rpm runs standard fuel and ignition compensation. :oops:
This is required for ethanol and methanol fuel
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
I don't see that tables in KPro. What is the starting issue you have with alcohol?
sass
Post by sass »
Hondata wrote:I don't see that tables in KPro.
Can you make a separate tab for the cold start?
Yes, I have problems with the first start the engine on alcohol.
Do You think I give a insufficiently amount alcohol (methanol) on startup?
Known as Sniper
