looking for KManager V1.2.2.8
kezay
Post by kezay »
I'm in need of this version so that I can download the current map the ECU has on it, and then install the latest software version and reload the map. I bought the ECU with this version on it (V1.2.2.8), so I cannot use any newer software version to download the map.
The current version should work. We do not send out old versios of software.
kezay
Post by kezay »
Review these threads and tell me what you think...
http://www.hondata.com/forum/viewtopic. ... t=kmanager
Basically its the same problem across the board... In order for you to download\access\make changes to a cal file you must have the same version of KManager installed. The problem is NOT ALL OF US HAVE all the version of KManager at our disposal.
Hondata get you act together, if people pay for a system I understand that you'll are trying to provide the best possible system but remember that instead of forcing users to use the latest software version, you should recommend that updates be done often. Older version of the software are important.
Abusive posts will be removed.
We do not give out old versions of the software. The reason is that downloading with an old version will corrupt the calibration. If the KPro has had a firmware update between versions, then KPro can be damaged.
Normally it will download as long as you close all the windows in KManager. If not, call for a RMA number and send in the ECU/KPro.
