AFR Gauge
chrisfjr83
AFR Gauge
Post by chrisfjr83 »
I am looking at installing an AFR gauge and was wondering if I can just get a gauge and tap in to wire on the ecu to get the AFR reading instead of having to install another sensor underneath the car? What brand does every one suggest to use??
No you cannot do that. Tapping in to the wiring for the O2 will cause problems with the readings the ECU sees.
chrisfjr83
So what O2 sensor and gauge do you all recommend on using??
We recommend PLX Devices widebands.
