I have an HF ECU in my garage and I want to convert my SOHC ZC civic to MPFI.
Can I use the PM8 ECU?
Should it be modified to run like a PM6?
Or, should I just find a stock PM6?
If I get a B-series engine later, can the HF ECU be modified to run it?
PM8
we (RaVer Motorsports) convert pm8 ecus to accept external roms...including chip $135.
this is not Hondata compatable, however. this really belongs on the non-hondata forum.
the best answer, though by far not the cheapest, is to convert your car to mpfi AND obdI at the same time. we have an ecu/sub-harness kit that makes the changeover fairly easy and then Hondata is plug-and-play.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
