Is VTEC engaging?
ej6.sean
Is VTEC engaging?
Post by ej6.sean »
I am new to s300 and cannot tell if my vtec is working? I get a spool error if its not disabled could it be the pressure switch?
98 civic dx, 2000 y7 block, jdm d15b head, 98 ex engine harness, OBD1 to obd2 dizzy step up harness, s300 obd1 non vtec dizzy leg is cut, off timing a little
According to the datalog, the ECU is sending a signal to activate VTEC. Beyond that I cannot tell anything from the datalog.
ej6.sean
Post by ej6.sean »
Hmm thanks for looking. I have right dizzy on now, drove and its still not cracking. Can't I hook up a test light to a wire that goes to the ECU C15 I think??
Try the ECU in a known working vehicle.
ROMEO856
Post by ROMEO856 »
it shows that your vtec pressure is not on...
