SManager V1.4.5 beta
V1.4.5.0
• Sensor window enhancements (alternating row colors to aid visibility, on/off parameters show as indicators).
• Graph window enhancements (better time axis labeling, ensure sensor labels are always visible).
• Table window enhancements (2D graph allows drag selection, 2D graph selects rows and columns with Shift and Ctrl clicks)
• Fixed PSP input increasing idle speed when PSP input used for other purposes.
• Added datalog comments.
• Parameters window now scrolls.
• Changed file association to work with Windows Vista / 7 security.
• Allow capital I and D when editing notes.
• Fixed 'Idle Speed Moving' table not showing temperature values in Celsius.
• Added support for Windows Themes.
• Added option to show 4 bar tables.
• Added option for closed loop using wideband lambda input.
• Added closed loop short term trim rate of change.
• Added burnout rev limiter.
turbotypeR
Post by turbotypeR »
Thanks guys!
What happened to the ign ramp back in for the strain gauge retard?
92 civic Si
best et:9.43best mph:164
Martian
Post by Martian »
Thank you thank you thank you for the wideband closed loop. This saves me a major headache.
thank you, thank you, I'm here all week
gherrera06
Post by gherrera06 »
Thanks to Hondata staff
Honda Club Panama
Corrperformance Tuning
Panama
GTMcoupe
Post by GTMcoupe »
Sounding very good gents
Keep up the good work!
West
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
turbotypeR
I have a question. Every time I download the newest version, it automatically adds all these calibrations I don't want. If I want to delete them or even move them to a new file, so I don't have to thumb through them, I have to do it one at a time, then go through two vista approval deals to get them moved. Is this the only way to do this, or am I getting too old and just don't know a better way.
92 civic Si
Just save your tuned calibrations to a different folder and you don't have to have all the other calibrations visible. It remembers the last folder you saved or opened from.
turbotypeR
Cool. That is easy enough.
92 civic Si
WickedCivicNY
Post by WickedCivicNY »
Very cool
thx
V-Spec race development
Post by V-Spec race development »
Thank you.
lowblow
Post by lowblow »
GOOD JOB HONDATA !
YOU ARE THE BEST !
HONDATA HELP US !
WE HELP HONDATA !
Ebola_One
Re: SManager V1.4.5 beta
Post by Ebola_One »
Hondata wrote:• Fixed PSP input increasing idle speed when PSP input used for other purposes.
<3 !
turbotypeR
What do you mean by "Parameters window now scrolls"?
92 civic Si
newsoltsc
Post by newsoltsc »
turbotypeR wrote:What do you mean by "Parameters window now scrolls"?
if you are using a netbook the parameter window would cut off some of the bottom window. Now that it scrolls we can scroll down and see the bottom half of the window.
-Jose
XPEHODATA
Post by XPEHODATA »
Hondata wrote:V1.4.5.0
It will be nice if closed loop with wideband can be target by target lambda table. Not only for one targed voltage.
Hondata wrote:• Allow capital I and D when editing notes.
And I and D not changed cells now. Only Ctrl-I and Ctrl-D....
If I change something in 2D by mouse than I can't undo this change.
