P1167 and P0134
Socal Sonny
P1167 and P0134
Post by Socal Sonny »
First off, i have an 03 rsx-s with complimentary bolt-ons.
i keep getting the P1167 error code. if i disable it i then get the P0134 code.
my readings show 0.00V for 02 sensor and 0.02V for 02C
the wiring to the 02 sensors seem to look fine. no burns and clips are fully on.
Secondly, if my primary sensor is bad; Is there anyway way to still datalog for tuning purposes?
thanks guys
kb58
Post by kb58 »
I don't get any error messages, but I also have 0.0V on the primary O2 sensor. Everyone feels I have it miswired, but with only two wires, it's not that hard. I also tried (and you can try this too) feeding in a very small voltage to the O2 wires, to see if the sensor's the problem. Nope, mine still reads 0.0V...
You can still tune, just check the box for "Tune engine open-loop" so that it ignores the O2 sensor.
Mid-engine K24 turbo Locost, http://www.midlana.com
You need to try your sensor in a known good vehicle, then try your ECU in a vihicle with a known good sesnor.
Socal Sonny
I should be getting a new sensor pretty soon.
hopefully its not the ecu
