Boost Problem
jiggacivic
Boost Problem
Post by jiggacivic »
i am having a problem with my s300 or car i am not too sure but what i found out is that in fourth gear my map sensor is reading 46 psi and i am getting boost cut and the car is only on 15lbs. i have a copy of the calibration file but i accidentally overwrote the datalog file, i am not too sure if the .skl file setting will tell anything.the map sensor i am using is xenocron 4 bar.
this is the datalog file that overwrote the one with the problem,don't think it will help though.
The datalog does not show the problem.
