FLASHPRO COMPATIBILITY? (SOUTH AMERICAN 2007 SI)
CSAS
Post by CSAS »
Dear Friends at hondata hope you can help me with this.
I live in South America and just bought a 2007 civic si and im interested in either the Reflash or the Flashpro.
The thing is that the car was built in Brazil and the ecu is a KEIHIN, made in UK, so i need to know if you can reflash this or if the Flashpro will work with my cars ecu.
The car info is the following:
* 2007 honda civic si (built in Brazil)
* K20Z32500492
* ECU number:33780-RRD-P11
* 7201-936590
* Modifications : Vibrant header with high flow cat, spoon air filter (replacement), vibrant muffler
Thanks in advance.
We recently added support for South America ECUs to the beta version, including the RRD-P11 ECU.
See http://www.hondata.com/flashpro_civicsi_purchasing.html and http://www.hondata.com/downloads.html
CSAS
Post by CSAS »
Hondata wrote:We recently added support for South America ECUs to the beta version, including the RRD-P11 ECU.
Thats great news.
Guess this is only a possibility only with flashpro and not for the reflash right?
Thanks a lot
Correct, only the FlashPro.
CSAS
Post by CSAS »
Hondata wrote:Correct, only the FlashPro.
Thanks for the quick answer.
This is available by using the beta software or theres a difference in the actal flashpro from the us market?
Any US version FlashPro will work using the beta software.
CSAS
Post by CSAS »
Hi, didnt want to open a new thread so i hope someone can hel me with the following.
Finally got to buy my flashpro and im ready to install it.
The only thing is that Flash pro manager, when I choose Vehicle in the calibrations, is giving me 3 possibilities for the South american verision of the Fa5:
-FG2/FA5 Civic si 2006-2011 South America (M)
-FG2/FA5 Civic si 2006-2011 South America (P1)
-FG2/FA5 Civic si 2006-2011 South America (P2)
The first one is giving me only a stock cal, but the other two have identical calibrations (based on the name).
What are the differences between those????
Thanks, and hope some one on Hondata can help me.
They may show the same main tables by the data behind the calibration will be different for each ECU variant.
Have a look at the part number on your ECU (37820...) and select based on that.
CSAS
Post by CSAS »
Hondata wrote:They may show the same main tables by the data behind the calibration will be different for each ECU variant.
I imagined that the data in the calibrations was different.
However, from my ecu part number, how i tell which one to select?
How can i tell is should use the P1 or P2?
my ecu is 37820-RRD-P11
P1
CSAS
Post by CSAS »
Hondata wrote:P1
Thanks for the help.
:D
Gonna use flashpro tonight!!!
