Setting up an S300 ECU
acidrelay
Post by acidrelay »
Hello,
I recently rebuilt the motor in my del sol, a B16A3. It has a JRSC on it with the LHT intercooler, and 440 injectors. I hooked up the ECU w/ the s300 on it and now I'm trying to start the car for the first time. Its getting too much fuel and i'm having trouble figuring out how to reduce the fuel to the injectors. I tried setting up the fuel trim, but with no luck. The car will start and run with the factory injectors and factory ecu in it so i know the motor is good. Any information would be helpful!
P.S. I tried to use the search function for the site without any luck
acidrelay
Post by acidrelay »
Bump
turbotypeR
Post by turbotypeR »
Did you input the stock injector size and the new injector size?
What injectors are you using?
92 civic Si
best et:9.43best mph:164
acidrelay
Post by acidrelay »
turbotypeR wrote:Did you input the stock injector size and the new injector size?
I did indeed. The stock ones are set at 240, and i'm using 440 rc injectors
acidrelay
Post by acidrelay »
bump
http://www.hondata.com/help/smanager/index.html
There is information in the help file on how to get started and use the software.
acidrelay
Post by acidrelay »
Thanks for your help :D I got it running yesterday. I had to reduce the entire low cam fuel table. I have a tune scheduled for march 20th. I just wanted to make sure it ran before getting it there!
