new ecu and same kpro
icekilla
Post by icekilla »
hi i have a hondata kpro and i broke my old ecu but the cip still works. I try it out on my friend kpro so i no it still works. I have a new ecu w/o kpro in it and what to know if i can just put the kpro in the new one and just soider the stems and jumper wires will that work or do i still have to do more?
serial number is 01774
firmware 1.00
No you cannot do it yourself. You will have to send in the old ECU with the K-Pro and the new ECU and it will have to be socketed by Hondata.
You need to contact tech support first and make sure that all troubleshooting has been done. If it is determined that it needs to be sent in there will be a charge of $100 for diagnostics and an RMA number will be issued. Depending on what is found there may be additional charges.
