Bard
Posts: 49 Joined: Wed Nov 25, 2009 2:53 am
Post
by Bard » Sun Feb 28, 2010 2:49 am
According to
http://www.hondata.com/immobilizer.html
Acura Technician types your car's VIN number into their desktop PC connected to Honda
The desktop PC returns a code which allows the immobilizer to be reprogrammed for your VIN number.
What VIN is typed ? From my old ECU that lies in a box now :), or from the new one reflashed that i recieved from hondata ?
And after reprogramming immo if i reinsert my old ecu back, removing hondata dual harness, will the immo work, or i should again reprogramm immo ?
Posts: 24337 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Mar 01, 2010 10:39 am
Do you have a dual adapter harness? Are you using the stock ECU from your vehicle still?
Bard
Post
by Bard » Mon Mar 01, 2010 2:48 pm
Spunkster wrote: Do you have a dual adapter harness?
Yes.
Spunkster wrote: Are you using the stock ECU from your vehicle still?
No. The stock ECU is in a table box now, but it can installed back if i`ll sell a car (cause i will sell it without dual harness).
Post
by Spunkster » Mon Mar 01, 2010 5:12 pm
What is the serial number of the dual adapter harness?
Bard
Post
by Bard » Tue Mar 02, 2010 4:46 am
Number on a blue box is 2608 or 7608 :)
Post
by Spunkster » Tue Mar 02, 2010 10:36 am
The immobilizier was disabled by the reflash to the stock ecu and cannot be reprogrammed.
Bard
Post
by Bard » Tue Mar 02, 2010 3:50 pm
You mean at all ? But i can enable immo thrue K-manager, there is an option ... and what about
http://www.hondata.com/immobilizer.html for what is this manual ???
Post
by Spunkster » Tue Mar 02, 2010 4:22 pm
That will not work with a dual adapter harness.
Bard
Post
by Bard » Wed Mar 03, 2010 4:45 pm
So if i understand you correctly there is no way for me to enable immo on my car ?
And what shoud i do with a flashing bulb ?
Post
by Spunkster » Wed Mar 03, 2010 5:06 pm
Just unplug the immobilizer in the steering column and the light will stop flashing.
Bard
Post
by Bard » Wed Mar 03, 2010 5:25 pm
O.k.
is there a way to enable immo ?
Post
by Spunkster » Wed Mar 03, 2010 5:39 pm
No there is not.
Bard
Post
by Bard » Thu Mar 04, 2010 1:56 am
If i`ll have a key and the immo from that car, from wich ECU was taken to buid dual harness.
Can this help solving the situation ?
Post
by Spunkster » Thu Mar 04, 2010 12:56 pm
No, the immobilizer cannot be used in this setup.
