change wastegate and stiffer spring
XtremeZ
Post by XtremeZ »
Hi, i have changed fron a replica wastegate to a genuine tial
wastegate but its now running stiffer
spring from the previous 0.6bar to a 1bar spring.. Car is running with pwn solenoid with boost by gear will i need a retune or which parameters will be affected? Thanks in advance
XtremeZ
Post by XtremeZ »
Sorry just to add, the new wastegate is the same 38mm as the previous one
You will probably need to re-enter the boost vs. duty cycle table to suit the needs of the new wastegate.
XtremeZ
Post by XtremeZ »
That was what i am think too.. Thanks for your time and input
