P0132 CODE k20a2 need help hondata please!!!!!!!!!!
innohs2
Post by innohs2 »
HI
I am stephane and i live in france near lille.
Sorry for my bad english language
i just finish my swap with a austin mini and K20A2
the full built here
http://www.16vminiclub.com/forums/showthread.php?t=7398
- serial number of your K-Pro :05343
- KManager version (not 'the latest'):1.3.9.0
- the calibration (as an attachment)
- a datalog of a problem (as an attachment)
- what sort of vehicle you have :a mini austin with a k20A2
- what sort of ECU you are using :PRA
- anything about the car which has been modified from stock which may affect the ECU : stock engine with full stainless exhaust pipe et cold air intake, no cat.
- a specific description of the problem :
engine start with no problem, after few minutes , a fault code come P0131 02 sensor low voltage .
i check with datalog and i saw the range for 02 normaly up to 0.9 down to 0,1v when is good but the mine never up to 0,2V.
i think sensor is wrong ;i decided to change , i bought a new sensor but isn't genuine honda parts.
is a WALKER oxygene sensor number part: 250-24473
This is a replacement sensor .
i make a good custom wiring ( double checked)
i restart the engine and put datalog
the sensor up to 1,02V and down to 0,2V and after up 0,3V And down to 0,2v never up to 0,9v .
and after few calibrtion, now the value stay at 1,02V.
And i have a fault code p0132 02 sensor high voltage.
can you help me please?
did need to change the sensor again (but for a genuine part)
[/img]
innohs2
Post by innohs2 »
my calib
innohs2
Post by innohs2 »
my datalog
02 sensor is in black line
thanks
help me to fix the problem please
kind regards
stephane
Try your ecu in a known good vehicle. If it works ok, then you know the problem is either with yoru wiring or your sensor. Also make sure you are starting from a PRA calibration from File, New.
innohs2
Post by innohs2 »
thanks you but i don 't have a ohter car to check my ecu .
IN datalog you can saw , 02 sensor not up to 0,9V and down to 0,1V
so i think the sensor this not good but is new?
a ohter idea?
kind regards
stephane
innohs2
Post by innohs2 »
some news
after rechecked the wiring , i have find a problem , i use custom hardness from minitec US and a k20a2 engine uk european.
i check the wiring about the 02 sensor and i find a difference.
wiring sensor o2 US engine
A6 : sensor+
A16:sensor-
A22:heater+
A1: heater-
but i have a european engine
can i change my wiring same a european engine like this
because on the harness engine european in the connector A there aren't wiring on the pin A22 and A16.
i think the signal don't came to the ecu
i found this wiring on hondata
1 is it correct ?
2 can i connect the wiring n°13 from the connector engine harness to the connecteur E pin 4.
3 does i need some other jump or modification?
my other problem is get a code p1259 oil pression swtich malfunction,i think is because i use a US engine harness connect to a european uk engine
4 can i disable the switch without any problem?
thanks you
please hondata and all guy help me
kind regards
stephane
innohs2
Post by innohs2 »
please help me i really need!!!!!!!!!!!!!!!!!
innohs2
Post by innohs2 »
helps me hondata !!!!!!
