02 sensor,whats the diffrence??
bruny
Post by bruny »
hi guys,i have a k20a2 eg with a us spec kpro installed,i had a p0134 code,so i bought this sensor off ebay,item number 130371089969 .installed it and its doin the same as the origanel sensor did,coming up with a cel,but this 1 runs lumpy at low revs when driving,my origanel sensor was a denso japan 1 with 103 near the threads.do i need a us spec sensor to make it right??
thanks guys
You need the primary O2 sensor form an 02-04 RSX. You could also have a wiring fualt.
bruny
Post by bruny »
thanks for the reply,wires have been checked and are all good,running a hybrid harness with us spec kpro version 1.2.24
will updating the ecu help??
You should always use the most recent version of software.
bruny
Post by bruny »
im getting the car a fresh retune next month i was just wondering if i should wait till the day i get the remap to install the new 02 sensor just incase i brake this 1 too.?
hankyou for your help
kb58
Post by kb58 »
Don't assume you broke it... it could be wiring (broken lead, intermittant connection, etc.)
Mid-engine K24 turbo Locost, http://www.midlana.com
bruny
Post by bruny »
kb58 wrote:Don't assume you broke it... it could be wiring (broken lead, intermittant connection, etc.)
thanks for your reply,what should i recheck on the wiring.it is intermittant at times,what should i check for this?
