MSD Distributor + Hondata S300
jdm97r
Post by jdm97r »
Hi Guys,
Does anyone ever had problems with the msd distributor connected to an S300?
My car shut off with these 2 connected together.
It revs to 4000rpm only sometimes
Then I put back the stock dizzy and everything back to normal
Any help please
On the datalog it doesn t show nothing
Honda Integra R JDM CW
Honda Civic EF 9.91@152 ... Sold
Honda Integra R EUDM CW SFWD 9.34 @158
We have found that the stock ignition system is best and capable of supporting up to 1000 hp. Many people experience problems with aftermarket ignition systems.
jdm97r
Post by jdm97r »
Spunkster wrote:We have found that the stock ignition system is best and capable of supporting up to 1000 hp. Many people experience problems with aftermarket ignition systems.
So you are saying,that there is nothing I can do,to make the Dizzy work with the S300?
fly_n
Post by fly_n »
Basically he is saying,why downgrade your ignition system when u have a perfectly fine,working stock system there which u mention.
jdm97r
Post by jdm97r »
I need a direct answer, There is something I can do to make them work together or not?
The MSD distributor is not giving the correct signal. Normally you only see this once the engine goes over 9000 rpm, and then it will rev limit.
There is nothing in the Honda ECU or S300 which can be changed to 'fix' the bad signal.
