Security "Tune" Problem.
firestrife
Post by firestrife »
So I went on vacation for a week. So last week I uploaded a security tune from flashpro.
It seemed to go swimmingly and the dashboard clicked several times i wasnt sure if it was normal for the Security tune. Anyhow I let it be and went on vacation and came back and now the ECU won't be recognized by flashpro.
I tried everything, from on-offing the ignition to disconnecting and reconnecting the battery but the OBDII port is recognized while the ECU is not.
The FlashPro tab says its in Recovery Mode but the status bar refuses to recognize this problem and just displays an "X" I tried following the help guide but it did nothing.
help is much appreciated.
Which calibration did you load?
What software version were you using when you uploaded, and what software version are you using now?
firestrife
Hondata wrote:Which calibration did you load?
I loaded the Security Calibration from the AFM/MAP tune config.
I am using version 1.1.4.4. when I uploaded.
Now I just updated before I came back to 1.1.4.5.
firestrife
anddddd
In the FlashPro software can you please go to Help, and click on Send Information to Honda Support. Please makde your you include a detailed description of the problem as well as your email address.
firestrife
Alright I just did that. Let me know if you guys got it and keep me up to date on what I should do.
Thanks.
nothing has been received. Make sure you are selecting the necessary options when sending it.
firestrife
Spunkster wrote:nothing has been received. Make sure you are selecting the necessary options when sending it.
Just tried again let me know if it got through.
still nothing, make sure you check the box.
firestrife
Spunkster wrote:still nothing, make sure you check the box.
Ugh, I check the box and I check my connection I did it like 3-4 times already. I think the problem is I don't have an internet connection where my car is.
I try to set it up and get the "send information to hondata" option and wait to get inside to send it still no go. :(
You do not have to do this at the car. Only the FlashPro needs to be plugged in.
firestrife
alright its sent and it confirmed with me this time.
please check your email
firestrife
Spunkster wrote:please check your email
Alright I just sent it today, should arrive by thursday hopefully.
firestrife
I don't believe this. but it's doing it again. all i'm ever doing is uploading tunes the same way I always have been. now its locked me out again. wtf. :cry:
