Startup questions pertaining extended warm/hot cranking.
soxfan143
Post by soxfan143 »
Hello Hondata. I would like to know what tables are controlling fuel directly after startup before it switches to closed loop. I'm having hot start long cranking issues and I can figure it out. It fires right up when cold but my wideband pins at 10 AFR flat until it goes to closed loop. Is that the cranking tables that I would adjust to get the open loop startup AFR more reasonable. Also, I would think that I need to get that AFR a little leaner before I start adjusting the ECT cranking fuel table. Correct? Thanks in advance. If you need a few logs and the cal I will post them.
soxfan143
Post by soxfan143 »
I actually found the info I was looking for in the help files. Sorry Guys. I'm still hazy on a few things though. It says something about short start trims. Is that a typo? Should it say that it uses the last short term fuel trim or start trim?
http://www.hondata.com/help/flashpro/tu ... art%2Btrim
I'm not sure what you mean by short start.
Where in the Help file are you referring to this?
soxfan143
Post by soxfan143 »
right after where it refers to note 4 in the second paragraph. It says closed loop start term fuel trim.
