AEM EMS with Hondata 4 bar MAP sensor
D1sclaimer
Post by D1sclaimer »
Hello, I have a 2000 s2000. I am running an AEM EMS 1052 for engine management. As far as mods go, it may as well be considered stock. Just exhaust bolt-ons and nitrous which is tuned through the nitrous control.
I recently bought a Hondata 4 bar MAP sensor since I will be going FI in a few months. I could not find the calibrations that I need to enter into my AEM EMS for it to work properly. I tried to use the Omnipower 4 bar MAP sensor calibrations and my car would not start. I swapped back over to the stock MAP sensor, put in the stock calibrations, and it started right up.
Heres the calibrations that I tried to use for it.
min voltage .08
max voltage 4.88
scalar 3.8
load offset 15.0
filter 10
frequency 0
Does anyone know what I need to do to get it to work properly?
-T.J.
We only use Scalar and Offset, so you may need to contact AEM to find out why it is not working.
D1sclaimer
Okay. I will probably end up going that route.
Out of curiosity, what Scalar and Offset values do you use on the KPro for the 4 bar map sensor?
Thanks again
-T.J.
D1sclaimer
Well I did a little bit more searching and found this thread which I think has my answer. I will reply if I can get it to work with these values.
http://forum.aempower.com/forum/index.p ... 339.0.html
Map min voltage 0.50
Map max voltage 4.80
map filter 15
Load offset 0.20
Load scalar 4.00
Frequency 0
-T.J.
D1sclaimer
I got it to start up and run with that.
I looked at my VE tables and I guess after you change the MAP settings, it rescales everything and changes it. I copied my old tune in to the correct values for my fuel and ignition. It ran very very rough though.
I just put the stock one back in and I'll see if my tuner can make some magic happen.
