FlashPro and oil sensor
Mityai
Post by Mityai »
After installing FlashPro disappeared from the dashboard oil pressure lamp!
Tell me - how can I make it work?
Oil pressure or oil level? With the AFM or race calibration?
Mityai
Post by Mityai »
the red indicator on the dashboard.
no lights!
Mityai
Post by Mityai »
we have MAP-based race calibration
oil pressure lamp doesnot work at all
What is your ECU part number? (37820-xxx-xxxx)
Mityai
Post by Mityai »
ECU 37820-RSP-E02
The oil level warning is not going to work with the race calibration. The oil pressure warning should.
Mityai
Post by Mityai »
unfortunately, oil pressure does not work
we've checked all MAP calibrations attached with Flashmanager, and the same result.
No oil pressure lamp at all
Can you access a wiring diagram for your vehicle and determine the pin used for the oil pressure input?
Mityai
Post by Mityai »
B7 pin, the same as on US Si civics
What has been modified on your Civic?
Mityai
Post by Mityai »
Spunkster wrote:What has been modified on your Civic?
Nothing, only JR and FlashPro!
http://www.drive2.ru/cars/honda/civic_t ... 888287741/
Have you checked continuity form the oil pressure sensor to the ECU pin?
Mityai
Post by Mityai »
We tried to load back to the standard firmware fn2, oil pressure lamp works!
gasss_85
Post by gasss_85 »
Is the oil level warning going to work with the MAF calibration????
Is the oil pressure warning going to work with the MAF calibration????
