closed loop operation
allm0t0rGSR
Post by allm0t0rGSR »
at the parameter, Maximum Map for closed loop, if i set it to 800mbar so if more than 800 mbar the closed loop operation will be disable, and it will go to open loop operation, and the short term and long term will be at 0%? so it wont affect my tunning at WOT?
correct me if i am wrong?
Correct as long as your long term trim is always 0 then it will not affect WOT tuning.
allm0t0rGSR
Spunkster wrote:Correct as long as your long term trim is always 0 then it will not affect WOT tuning.
thanks....
so you mean even do the cloosed loop operation is already disable at 800mbar over, the long term will effect my wot tuning?if that so is there anyway to diable it? why there is a long term?what has been happened when theres long term?
The only way is to run in open loop. Long term trim means that it has had to add or subtract fuel based on the closed loop settings.
allm0t0rGSR
ok thanks alot
