ls/vtec
eptcoupe
ls/vtec
Post by eptcoupe »
i have a 2000 coupe with ls/vtec running a p2t ecu with no knock sensor. does hondata have something to trick the ecu into seeing the sensor or what are my options
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
