Help with Tech edge wideband syncing to s300.
josh green
Post by josh green »
I have an older Tech-edge wideband that came in my car and I am trying to sync it with s300 for datalogging. The wiring is ran properly to my knowledge, I am using the O2 pin on the ecu for input. The wideband that I have only has an RS232 jack for output and it says on their site that pin 7 is the one needed for output to log. Well I have ran the wire and I have turned everything on and set to the suggested settings in hondata and have been messing with the voltage offset and nothing is working. I have heard that I may need to run a ground wire from the output on the wideband but am unsure of which pin. I have searched the tech edge site and its kind of confusing to me. I believe its pins 5&6 are grounds but I am unsure of which goes with the O2 if it even does at all? You help is greatly appreciated!
It sounds like you will need to contact the manufacturer of that wideband and find outif it has a linear output (0-5v).
http://www.hondata.com/techplxwiring.html
