AFR and Fuel Pressure Question Please Help
spazz-x
Post by spazz-x »
i have a 2009 civic si with the CT stage 2+ and ingen CAI and im using the hondata flashpro tune also im running a completly stock exhaust, what scares me is that i have the full invidia header and catback Q300 coming on monday and if my AFR's are this high now i assume it will only get worse with a full exhaust. so heres my question how do you know if you crushed the fuel pressure regulator properly the reason i ask is my AFR's are sometimes in the high 13's and my injectors are at 98% duty cycle so please any input would be apreciated.
also when i first start boosting im at about 14 then it slowly goes down to the high 12's by the time im at peak boost (around 10.5 psi)
Check your fuel pressure at idle, it should be about 10 psi over stock. You may want to contact C-T Engineering to get specifics.
