help please.. no cam advance
leighep3
Post by leighep3 »
My car is being mapped at the minute and the tuners has come across a problem the cam will not advance and is permantly set at 0% no matter what he tell it to be set at. can anybody help me asap please.
its a ukdm ctr k20a3 running a turbo conversion. i really need help.
thanks leigh
leighep3
Post by leighep3 »
car. ukdm ep3
hondata kpro ... serial number 37820-pra-e12 187213-4105
k manager 1.4.0.0
short spec is turbo(t04) rc 650cc injetors, 4bar map sensor,
description of fault is set low and high cam to 30deg run car on dyno cam commander is 0 deg and cam is 0deg.it will not let me adjust. always satys on 0 deg?
Can anybody please help with me for idea`s
VTC is disabled because of error codes. There's three main problems:
- IAT sensor error
- primary o2 sensor error
- a PRB calibration was loaded into a PRA ECU.
leighep3
Post by leighep3 »
Hondata wrote:VTC is disabled because of error codes. There's three main problems:
- IAT sensor error
yeah i thought so mate. thanks for your help..
the IAT error is because the sensor needs to be placed in the intercooler piping just before the intake i think?
the primary 02 error fault is because it currently had a wideband in the exhaust instead of the 02 sensor. and its running open loop atm..
thanks again for your help
tommykair20
i have almost the same problem
Post by tommykair20 »
2002 civic Ep3 "kpro PNF"
k manager v 1.4.0
ep stock intake manifold
k24a2 engine stock from a 04 tsx
t3/t4 turbo Stage III
650cc
9.5 lb flywheel
stage 4 clutch
my tuner command cams to 35 degree but it will only go and stay lock to 21 degree...
is it possible that my vtc gear is damage???
A TSX engine has a 25 degree VTC.
