Settings dont save?
Gen2ITR
Settings dont save?
Post by Gen2ITR »
I go to the options drop down>setting> Analog Imput 1 tab.
I set the voltage table correctly. While dataloging everything works great (hondata seems to respond the the voltage fluctuations faster then the AEM) but once I save and close everything, I have to go back thru and redo all the voltage settings all over again.
Also is there a way to remember the window size and position inside the SManager...Similar story...Get everything set where I like it, but upon re-opening, everything is back to original.
Thanks!
Both of these settings should be retained. If they are not, then Windows is probably doing something odd with the settings file.
Look in the help under 'Vista Virtualization' for the location of the SManager.ini file. In Windows exporer, check that this directory path exists and that the SManager.ini file is not read only.
Gen2ITR
Post by Gen2ITR »
That seems to have been the case! Took awhile for Vista to allow me to make any changes (Bastards!) but everything is functioning perfectly again!
Thanks for the quick response and great customer service!
