Random RED led and stalls
migee
Post by migee »
Hi everyone,
I've been having problems lately with my hondata, or at least I think it is the hondata. The car will work perfectly fine, then the engine just dies, and CEL goes on, and when I look at the hondata ECU I see a solid red LED. The rest of the car works, ie. blinkers, fuel pump priming, cranking (but it wont start).
I was able to have it happen again today while accelerating out of the driveway and when I hooked up the laptop, I received a 'floating point division by 0' error when trying to download the map/datalog. I tried again and it worked (but red led/cel still there). When datalogging nothing was changing at all. After turning the car off and cycling a few times it jumped back to life.
I think the problem is with how the chip is seated. Does anyone else have any suggestions? Can anyone explain how to reseat the hondata unit? Is it soldered in, or just pushed in (into a zif socket or something)?
*ignore emanage, its not hooked up*
b16spaz
Post by b16spaz »
i to have been having a similar problem. at completely random times the car will just lean out or over fuel to where it dies it also sill just crank and wants to start but just dies like yours. i to am very interested in what could be causing it.
and it has only happened since the fuel tank ran out once maybe fuel pump? but the fuel pressure is fine?
car is a 00si w/ phearable s300
From help, about, what version of software are you using?
b16spaz
Post by b16spaz »
V1-4-5-0 the latest one i was just driving it around just fine and the pulled over for a min to look at some sensor data then went to drive off and it just started spitting and died then wouldn't start back up.
