Injector error for a Hondata P28
n2boost
Post by n2boost »
I have a Hondata P28 for a 2001 integra GSR. The numbers on the side are: P28-OBD2B H273013 H0BDIIB with pins. Do I dissable the injector error or not?
2001 Turbo GSR, BB SC61, 1000cc injectors, stock block w/block guard, arias pistons, eagle rods, p28 w/s300, LSD, Type S BOV, Tial 38mm w/g, blox manifold, 3" down pipe, Thermal 3", Zex turbo cams, AEM gears, MSD 6BTM
you shoudln't have to, but if you get the error then disable it.
