stall/idle issue
kateglsvtec
stall/idle issue
Post by kateglsvtec »
when my car gets to temp (around 170-and up and the fan is on) and im coming to a stop have the clutch in an my foot on the brake the car will just stall then when u start it back up it doesnt want to idle but sometimes it will.....any help would be great thanks
p.s i have searched and read threw all of the help section on idle and many other and i have adjusted everything i can find with idle it just seems to do it when theres alot of vac pull... on brakes in neutral coasting to a stop it dies
ls/vtec
s300
toda b cams
bisimoto header
itr intake manifold
Do you have a aftermarket flywheel?
kateglsvtec
Spunkster wrote:Do you have a aftermarket flywheel?
yes i do sir.....i read that on here somewhere that people were having issue with that any ideas of how to fix?
you can try to move the slider to the rigght in the idle parameters, but that may not solve the problem. THe problem is not enough inertia to keep the engine turning.
kateglsvtec
Spunkster wrote:you can try to move the slider to the rigght in the idle parameters, but that may not solve the problem. THe problem is not enough inertia to keep the engine turning.
yeah i have tried that not all the way to the right tho ill give it a shot.....any other ways to maybe fix it....thanks
bryant
Post by bryant »
i'm having the same problem. is there any other way to fix this?
bryant
Post by bryant »
anyone?
