Hondata think im in 5th when im in 4th
SPOOLIN
Post by SPOOLIN »
I used to never have this problem, hondata would always know what gear im in. The only thing i changed that could cause this is puttin in my liberty transmission. I input the gear ratios into the table and the FD. When i hit 4th gear it thinks im in 5th, but it blips 4th gear for a split second in the logs. Now i have to load what i want boost wise into the 4th and 5th gear charts to make sure i get the right boost control. Any other things to look at to figure this out?
www.MSSRACING.com
9.29 | 6.20 | 167
I see some teeth counting in your future...
SPOOLIN
Post by SPOOLIN »
I've tried all of the ratios that Liberty sells, none read 4th right. Are the b series speed sensors different from each other? ls vs gsr?
www.MSSRACING.com
9.29 | 6.20 | 167
To my knowledge there is no difference between the speed sensors.
