unable to select values
turbo-2nr
Post by turbo-2nr »
i noticed in the new beta v1.4.7 i cannot select values like in voltage/lambda conversion tables and gear comp, and i know the values can be changed because iv done it be for, any one have a clue
locash
Post by locash »
No problems on my end, can you describe the process you are going through?
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
turbo-2nr
Post by turbo-2nr »
i click on it and it dont work, its like locked out iv been using s300 for about 4 years and have never had this problem
locash
Post by locash »
Post your calibration file.
Locash Racing, LLC
If you have just downloaded from the S300 then save the calibration to the hard drive and re-open. Otherwise give us a screenshot of where it is going wrong.
turbo-2nr
Post by turbo-2nr »
i thought it was maybe because i downloaded from the ecu but i tryed opening another calibration and it still wont let me change it
