broken s300 ecu burnt
importkingclo1
Post by importkingclo1 »
okay well today while trying to tune my car i notice when i turned the key in on position the pump didnt prime, so i was like what the **** i broke something or wiring trouble so i sat there and ran through the whole car only to figure out after swapping ecus thatmine is messed up, so i took it apart and one of the small diodes or whatever are jacked up and on the buttom of the motherboard its burnt like, QUESTION IS THE S300 UNIT STILL GOOD AND IS IT ABLE TO BE REMOVED AND PUT INTO ANOTHER ECU
The S300 is probably ok, but the best thing to do is to try the S300 in another ECU to see.
importkingclo1
well either way its not to possible to do so, due to the way the s300 is pinned
locash
Post by locash »
Obviously, it is possible, you just either need some header pins, or you need to prep another ecu..
What component is burnt in your ecu, or what location is it at?
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
