Online problems
cukali
Online problems
Post by cukali »
2005 Si with K24 swap and turbo.
When I use my charger while tuning, I lose communication with ECU. Three different laptops all do the same thing. How do I solve this?
Also, I noticed while in "IGN" view in 3D map, the tracing is not following the IGN but appears to follow MAP but displays are in IGN degrees. In 2d view it appears correct. Anything odd about this?
IF it only happens using the charger it is because the charger is picking up or generating extra interference and interupting the datalog data stream. Are you using resistor spark plugs?
cukali
Post by cukali »
Yes, i use resistor plugs.
